downloaded components
3 REPLIES 3
a8005873
556 Views, 3 Replies
I have dowloaded a componet to put in my model. However, in plan view it shows up as the outline of the object.
Can someone tell me how to show the actual item in plan view.
3 REPLIES 3
a8005873
in reply to: a8005873
This is the view from the level 0 and from all the other levels
a8005873
The problem was that coarse was selected in the plan view meaning that I was unable to see it.
LisaDrago
So you have figured it out?
If you need to see more you can edit the family and rest the visibility of the family.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
