Download Imperial Library for Revit Architecture 2013
7 REPLIES 7
Message 1 of 8
pmarjeram
19087 Views, 7 Replies
Where will I find the Imperial library for Revit Architecture 2013.  Being in Canada, our firm usually only downloads the Metric library.  It would seem one of my users suddenly has a need for then Imperial library.
Thanks in advance for any help.
7 REPLIES 7
Message 2 of 8
Lineabove
in reply to: pmarjeram
The library is on the installation DVD.
Insert DVD and select "Change"
You will see the Libraries which you may select to install.
Message 3 of 8
Chris.Aquino
If you installed from a downloaded installer you can also load the libraries by going to Programs and Features in the Control Panel, select RAC 2013, the Change. Once in the install wizard you can select the libraries to install.
Chris Aquino
Adoption Marketing Manager | BIM Collaborate Pro
@Aquinotecture
Message 4 of 8
in reply to: Chris.Aquino
I am having the same problem.
I am using Autodesk Revit Architecture student edition 2013 which I downloaded from the Autodesk website.
I tried this..."If you installed from a downloaded installer you can also load the libraries by going to Programs and Features in the Control Panel, select RAC 2013, the Change. Once in the install wizard you can select the libraries to install..." but when I clicked on 'Autodesk Revit 2013' under 'Programs and Features' and right clicked 'change', it only gave me the option to 'upgrade' my content pack to English: australia... I couldn't see anything about the Imperial Library.
Can anyone assist with this?
thanks
Message 5 of 8
Lineabove
Hi, I do not remember exactly but if you do not select anything in the first screen and then select NEXT to go to the next screen, does that provide the option for the various content packs?
Message 6 of 8
welcome
Tags (1)
Message 7 of 8
Message 8 of 8
sksiraj1143
Where will I find the Imperial library for Revit Architecture 2013. Being ini india our firm usually only downloads the Metric library. It would seem one of my users suddenly has a need for then Imperial library.
