We had purchased the Adesk Building Design Suite 2012 and are on subscription as of now. Since the new release 2013 has come we believe we can upgrade it to 2013 release since we are still on subscription.
My question is after my subscription ends, can we still downgrade our Suite from 2013 to 2012 or 2011 (If for Some reasons) ???
Please assist on this
Solved by LisaDrago. Go to Solution.
You have upgraded your software to 2013. As long as you are on subscription - you have access to 2012, 2011 and 2010. If you do not continue your subscription - you will no longer have access to the previous versions. That is a benefit of being on subscription.
Think of it this way - I had a 2000 KIA Sephia - I UPGRADED to a 2010 KIA Soul. I no long have use of the 2000 Sephia. That is essentially what you have done. But by being on subscription you have the privilege of using the older software. If you are not on subscription - you lose that benefit.
Does that make sense?
LD
yes but when i try to activate what serial and product key should i use? the same on i have for building design suite 2013???
