Is there a way to build a double sloped floor os something similar on Revit?
I'm working on a project that has an open parking lot. The site has a slope in an "east-west" direction and also because of the levels of the project the parking lot needs to have another slope in the "north-south" direction, so the parking lot floor should have a double sloped floor. I'm using a building pad to cut some of the site (the topography is pretty irregular) and I'm also using floors for the parking lot.
I hope you understand what I'm trying to explain.
Greetings,
Solved by constantin.stroescu. Go to Solution.
Thank you for your response.
Yes, I'm trying to do something like that to a floor, is it possible?
There are two methods:
The first method allows multiple slopes and it is a better solution
The second method allows only one slope....
Here you can find a screencast showing The Sub Elements and the Slope Arrow methods:
https://screencast.autodesk.com/main/details/bf64ad62-7354-4e85-83ed-c0f51e65f76
Your Name
https://screencast.autodesk.com/main/details/bf64ad62-7354-4e85-83ed-c0f51e65f761
Your Name
