Revit Architecture
sparrowitis
Message 1 of 6 (317 Views)
Double glazed curtain wall
317 Views, 5 Replies
11-15-2004 08:00 PM
What is the best way to create a double glazed curtain wall that is attached to an internal aluminium frame? In plan section I need to see a panel of glass/vacuum/glass, with aluminium mullions at the joins.
*Scott Davis
Message 2 of 6 (317 Views)
Re: Double glazed curtain wall
11-15-2004 08:23 PM in reply to: sparrowitis
create a new curtain wall panel that has glass/vacuum/glass, and swap out the panels. "sparrowitis" wrote in message news:13274655.1100577645038.JavaMail.jive@jiveforum1.autodesk.com... > What is the best way to create a double glazed curtain wall that is attached to an internal aluminium frame? In plan section I need to see a panel of glass/vacuum/glass, with aluminium mullions at the joins.
sparrowitis
Message 3 of 6 (317 Views)
11-15-2004 10:19 PM in reply to: sparrowitis
I have tried to create a curtain wall by duplicating an existing curtain wall, but unlike the regular walls, I cannot edit the structure of the curtain walls. Any further suggestions?
*Aaron Rumple
Message 4 of 6 (317 Views)
11-16-2004 06:13 AM in reply to: sparrowitis
Structure? As in mullion spacing? "sparrowitis" wrote in message news:25206682.1100586020315.JavaMail.jive@jiveforum1.autodesk.com... > I have tried to create a curtain wall by duplicating an existing curtain wall, but unlike the regular walls, I cannot edit the structure of the curtain walls. Any further suggestions?
*Scott Davis
Message 5 of 6 (317 Views)
11-16-2004 08:11 AM in reply to: sparrowitis
Curtain wall panels are families. You will need to open an exisitng curtain wall panel and edit it and 'saveas', or start a new family with the Curtain panel template. After creating the panel, you will be able to switch the panels for the new one. "sparrowitis" wrote in message news:25206682.1100586020315.JavaMail.jive@jiveforum1.autodesk.com... > I have tried to create a curtain wall by duplicating an existing curtain wall, but unlike the regular walls, I cannot edit the structure of the curtain walls. Any further suggestions?
*Jeffrey McGrew
Message 6 of 6 (317 Views)
11-17-2004 10:07 AM in reply to: sparrowitis
sparrowitis wrote: > I have tried to create a curtain wall by duplicating an existing curtain wall, but unlike the regular walls, I cannot edit the structure of the curtain walls. Any further suggestions? Yeah, curtain panels are a separate family. But now in Revit 7 you can use normal wall types as a curtain panel. So the really simple way to do what you're looking for is to first make a new basic wall type called 'Dbl Glazing' or something, make it 'glass-void-glass' within the wall construction parameters, and then after you've drawn your curtain wall select the panels and swap them for that wall type... Jeffrey
Announcements
Need installation help?
