Revit Architecture
Revit Architecture
New Member
jessie17
Message 1 of 4 (2,363 Views)
Doors will not show up in first floor plan of Revit
2363 Views, 3 Replies
11-02-2011 01:59 PM
So I'm having a strange issue...
Somehow today all the doors and cased openings dissapeared in my first floor plan.
They show up in the 3d views, sections, and second floor plan, but not in the first.
I have checked the visibilty settings, and they are all checked and correct, and I have checked the height of my floor cut, which is adequately at 4 feet high. Additionally, if I make the detail level "fine" then the casings will show up around the wall but the wall will not show the door cut.
The doors show up in a previous version of the model, so I'm not sure what has happened to cause the dissapearance.
Any thoughts?
ccollins
Message 2 of 4 (2,344 Views)
Re: Doors will not show up in first floor plan of Revit
11-02-2011 02:19 PM in reply to: jessie17
Check the VG settings in your view under Doors.
see attached.
Cliff B. Collins
Registered Architect/BIM Manager
Thalden Boyd Emery Architects
St. Louis, MO
New Member
jessie17
Message 3 of 4 (2,341 Views)
11-02-2011 03:17 PM in reply to: ccollins
Thank you for the help. I had already checked that, but for future reference my doors had changed to the wrong level. Easy fix. Thanks!
Jess
New Member
nickbaker10
Message 4 of 4 (1,874 Views)
10-25-2012 12:33 PM in reply to: jessie17
This definitly helped me out because i found my doors but how did you get your doors to go to right plan then?
