Revit Architecture
Rebel1
Message 1 of 5 (2,476 Views)
Door Tags
2476 Views, 4 Replies
09-13-2012 09:13 AM
Being new to Revit I placed doors throughout my plan, but the door tags do not show.  How do I turn them on and off for doors window etc.?
Active Contributor
jesser
Message 2 of 5 (2,462 Views)
Re: Door Tags
09-14-2012 06:25 AM in reply to: Rebel1
Did you tag the doors in addition to placing them?
If you did tag them then check visibility graphics and under the annotation tab check to see if door tags are unchecked.  If so check them on to be visible.
If you didn't tag them then you can easily use the Tag All tool located under the Annotate tab.  In your view of choice to see the tags, choose the door tag (under Tag all) and voila all your doors are tagged.  (assuming that door tags are on in visibility graphics)
Jesse Remick
"Sometimes the solution is so clear you see right through it."
New Member
harold
Message 3 of 5 (2,217 Views)
Re: Door Tags
04-22-2013 09:36 AM in reply to: Rebel1
Hey, I've got a door located on a diagonal wall that needs to be tagged. See where I'm going with this? Anyone got any ideas how to get a diagonal door tag. Revit has only the two options horizontal and vertical. Like Help!
constantin.stroescu
Message 4 of 5 (2,201 Views)
Re: Door Tags
04-22-2013 12:17 PM in reply to: harold
select the door tag , click on Mode>Edit Family
in Family Editor >Properties>Rotate with Component>check it and load it into project again
Constantin Stroescu
BIM Manager AGD
New Member
harold
Message 5 of 5 (2,192 Views)
Re: Door Tags
04-22-2013 01:16 PM in reply to: constantin.stroescu
Hey Thanx Boss, Rotating the tag kinda works. In the normal tag mode there are horizontal and vertical options. The Rotate with component check box works but not give options, i.e. dia 45 deg. or 135 deg. We'll work with it a bit more see what works. Thanx hgf
