so i have a created double door that I need to change to a doubkle swing door. I know i need to create an angle parameter but what happens to me every time i do this, is when i swing from 45 to 90 and then try to go back to 45 i get the messages below. How do i fix these error messages?
Constraints are not satisfied Reference Planes : Reference Plane : id 7148
Lines : Symbolic Lines : id 7870
Dimensions : Angular Dimension Style : Parameter : id 8010
Constraints defined by highlighted Lines and Dimensions can't be satisfied. Lines : Symbolic Lines : id 3147
Lines : Symbolic Lines : id 3148
Lines : Symbolic Lines : id 3149
Lines : Symbolic Lines : id 3150
Dimensions : Linear Dimension Style : Parameter : id 5229
Lines : Symbolic Lines : id 7869
Lines : Symbolic Lines : id 7871
Lines : Symbolic Lines : id 7872
Dimensions : Linear Dimension Style : Linear : id 8016
Dimensions : Linear Dimension Style : Linear : id 8023
Use a Reference Line, instead of a Ref. Plane for the angular dimension reference.
Could you attach the family you are using so we can have a look?
like i said in my last post is that i only saw the error message when inside the rfa file but once i put it into a project the swing works without error, but i have no idea why it would work inside the project but not in the rfa file
