does anyone know If it's possible to do a door or window schedulle with a field like that - Height X Width / Sill Height???
Maybe there's some formula, or some way to do this as a shared parameter?
Thanks a lot!!!!
Make a door schedule
Add in Fields (beside the others) the following parameters:
Your Name
Sorry, I think I wasn't clear enough. I need something like a mixed field, for example, for a door with width (70cm), and Hight (210cm), so I need a field like : 70 X 210 (70 by 210), did you understand?
