Revit Architecture
Valued Contributor
kwihae
Message 1 of 5 (1,258 Views)
Door schedule- show host wall type
1258 Views, 4 Replies
01-03-2012 08:12 AM
What kind of an instance paramater needs to be implemented in order to account the host wall type in the door schedule?
Thank you
Employee
loboarch
Message 2 of 5 (1,239 Views)
Re: Door schedule- show host wall type
01-03-2012 01:18 PM in reply to: kwihae
The host wall of a door is known to Revit internally but not exposed to the user in any way.  It can't be scheduled using out of the box tools.  Usign the Revit API a custom application could be written to access this information.  it does take programming knowledge to access and use the door's host wall information.
Jeff Hanson
Sr. Subject Matter Expert
Autodesk, Revit User Experience
Active Contributor
GlynnisP
Message 3 of 5 (1,228 Views)
01-03-2012 06:09 PM in reply to: kwihae
Host Wall and Host Wall Type-based data are among the types of parameter data that Ideate BIMLink supports - see image.  Grabbing the area of the wall in which a window is hosted is a similar type of task.
Glynnis Patterson, Architect
www.ideatebimlink.com
Active Contributor
Chris_Baze
Message 4 of 5 (63 Views)
07-30-2014 07:28 PM in reply to: GlynnisP
Host wall type is still only accessable through the API in 2015, correct?
Active Contributor
GlynnisP
Message 5 of 5 (46 Views)
07-31-2014 05:08 AM in reply to: Chris_Baze
That is correct.
-Glynnis
