Door Heads in RCPs
2 REPLIES 2
blastula99
207 Views, 2 Replies
Door Heads in RCPs
Is there a way to get just the door heads to show up in an RCP?
I have quickly looked at view props as well as trying to add a symbolic line to the door family but am not having any luck.
Any help is appreciated.
2 REPLIES 2
in reply to: blastula99
1. Make sure your cut plane is below the door head
2. Turn off the 'Doors' category in the Visibility graphics override for the
RCP view. You may turn off the door sub-categories selectively if you want
to see some door elements in your RCP.
HTH
Ishtmeet Singh
Ideate,Inc.
www.ideateinc.com
wrote in message news:5442332@discussion.autodesk.com...
blastula99
wow. that was rather obvious!
Thanks.
