Create a Project Parameter called Fire Rating (Required), make it an Instance Parameter and apply to walls doors and window categories. The same thing for acoustics is also very usefull, means you dont end up with needless multiple 'Types' of families
I recently came across this method for changing the fire rating parameter in doors from type to instance. Here's how:
1) In the door family, add a value to the fire rating type parameter
2) Change the category of the door family from door to generic model
3) Edit the fire rating parameter, change it to 'instance'
4) Change the category of the family back to door
5) Reload into project
When you schedule doors and include a field for fire rating, the column will include both instance and type parameters from various doors.
I can't vouch for whehter this has long term effects, but it works!
