Three pdf's attached. I can't get the glass in the glass sidelight to display in the project plan view, and a threshold-like thing is shown in the project plan view that shouldn't be there. The frame (jambs, sidelight sill and head, and door frame head) and glass sidelight were assembled in the family editor using extrusions.
Thanks much for your help from a new user.
Solved by constantin.stroescu. Go to Solution.
in Family Editor:
Ref Level > select elements that appear /not appear in Project , one by one and > verify Visibilty Settings > hide or unhide entities as you want and then reload to the Project....
Your Name
