Is the attached possible? I'm trying to cut out the plaster wrap to a wall, but can't figure out how to do it.
I've had a look at using reference planes in the door family object, but they don't seem to be able to do this?
Simply checking the wall type to wrap at only the external insert isn't going to work as I want the recess in the plaster to be away from the door frame edge.
Solved by ChuckEdwards. Go to Solution.
the steps:
Attached you can find a rfa file with these....
Constantin, just trying this, using an existing pocket sliding door type I've found on Revit City, I've created a Void>Extrusion, yet for some reason it doesn't cut the wall? Could you suggest where I'm going wrong with this?
I can see the void object alright but there is simply no cutting happening, unlike with the existing extruded void in this door family object.
The properties of my small void (orange) and the existing also see different?
Found it, hadn't gone to the Modify>Cut Geometry tool, and extra step I wasn't aware I needed.
Do that and it cuts fine...
Thanks for your help!
