really? I care only about the door schedule - does this mean we need say 5
kinds of doors (glazed, slab etc) x 6-7 sizes x 3 formats (single, double,
double unequal sides) or 90 door types?
shared instance would limit that quite nicely and work in the door schedule.
TDP
First things first, but not necessarily in that order.
The Doctor
wrote in message news:6345198@discussion.autodesk.com...
A door schedule is typically setup to look for families then by type. If
you change them to instance parameters you'll have a mess, quantity takeoffs
will be inaccurate as well. Thought about the same thing when I first setup
our templates and quickly found out that it was a bad idea.
