Solved by tomek. Go to Solution.
Hi.
Could you elaborate slightly on "drag your windows and doors onto it" please.
drag them from where?
Once you have created a new Legend View
Go to Annotate Menu- Legend Component and then choose what you want to add from the Options Bar drop-down
See screenshot
You drag them from the family browser. Navigate to the right family in the family browser and find the types that you want to document. Then just drag those right from the family browser into your legend.
Upon placement they will display in plan view but if you look at the options bar there is a menu there where you can change it to elevation view.
This also works for most other families, just drag and drop into your legend view. You will be able to dimension and annotate these items but you won't be able to tag them, that's a current limitation of the software.
cheers,
-tomek
What "options bar" are you talking about? I literally have no options to make an elevation from my legend plan.
These forums need to either be more thoughtful, or post screenshots of every step.
About 75% of these forum responses are completely useless.
So I found the options bar. What you failed to mention is that the elements have to be selected for the options bar to show up.
This might seem obvious to some- but a help forum is by definition a place for people who don't know how to do something. And often that person is a beginner.
People are trying to help you and you call their contributions useless? what kind of entitlement do you think you have?
Everybody that responds on these forums do so to help others. We are not paid to do so. It is a users forum and users spend their own time trying to help others. What are your contributions to the forum till now?
Someone gave advice on the query that you had. It was relevant to your question. So you missed a step. In order to become competent with the software, you also need to explore for yourself - most people here improved by trial and error.
Elaborate on how you came to a figure of 75% of posts being useless. Many users have had there queries solved here, for free.
Please show some gratitude.
Is there any way of adjusting parameters to suit what has been adjusted in the model? (i.e.) window trim visibilty.
@tomek :
I may be missing something... You mention that you "will be able to dimension and annotate" but not tag items. If I try to dimension, nothing seems clickable or highlight in a way that can be selected to be able to dimension. Is there something I'm not aware of to make this possible?
