Does upgrading Revit 2015 require upgrading to Revit Server 2015?
1 REPLY 1
Jroper
358 Views, 1 Reply
Also, does a newer version of Revit Server still work with projects that are 2014 or below?
1 REPLY 1
Chris.Aquino
in reply to: Jroper
Each version of Revit will only work with the corresponding of Revit Server. Therefore, if you have projects in 2014 and 2015 you will need to have both Revit Server 2014 and 2015 installed.
Chris Aquino
Adoption Marketing Manager | BIM Collaborate Pro
@Aquinotecture
