does revit have a command similar to xref
5 REPLIES 5
angelabill
4850 Views, 5 Replies
i am detailing an apartment building and want to know how to copy a typical unit so that when i modify the original unit it will automatically update the copied units
5 REPLIES 5
in reply to: angelabill
Yes Import on the File menu. You can import and link DWG's, DXF's, DGN's, other Revit Project files.
Mel Persin, AIA
Look into creating a group of your apartment unit and then insert a copy of
that group.
If you change the group it will update all the other groups.
From;
Edward Borg
Precision Drafting LLC
Http://Precisiondraftingllc.com
angelabill
thanksfor the advice
angelabill
thanks for the advice
From what I understand it seems that you need a group, not a linked file.
