Does Revit 2014 come all in one package?
I’m not sure if Revit 2014 Architecture/structure/MEP are coming in one package or one can download each one separately
http://www.autodesk.com/products/autodesk-revit-family/free-trial
Best
Jamal
The only way to get Revit 2014 (containing Arch, MEP & Struc) is to purchase the Building Design Suite Premium or Ultimate.
LD
Many thanks Lisa fir the answer,
What I wanted is the other way around! I wanted to download the trail version separately for Architecture and structure but sounds no option to do so.
Then how one can download a trial version of Revit 2014 Architecture and Revit 2014 structure separately?
Best
Jamal
Whops!
I am not seeing where this can be done... I will keep looking...
LD
There are some changes in trial download in 2014 version.
In Revit 2014, I see that there is no download option, only install now. Assuming that you see the same button, you should be able to install Revit and choose only Architecture option. Therefore, it will not download files required by MEP and Structure.
I'm not sure if in other region people are still able to download it though...
Many thanks Edwin,
I’m wondering why downloading/installing the Revit is still complicated (attached)
Best
Jamal
Yeah, many of us having hard time downloading from subs center.
I expected installing products directly from web will be more difficult.
If you fail installing it, you need to install it from website again. You can't reinstall it from local file.
Try this to check frequent problem with install now: http://upandready.typepad.com/up_and_ready/2013/04/general-installation-installing-autodesk-products...
Many thanks Edwin for the help,
Hope that autodesk will enhance the download soon
Best
Jamal
