Also note the Silhouettes option under Advanced Model Graphics for the view.
Set it to a heavier line, then linework the distant edges.
wrote in message news:5439197@discussion.autodesk.com...
Use the linework tool and/or play around with the Projection vs Cut
lineweights under visibility/graphics.
wrote in message news:5439169@discussion.autodesk.com...
In a plot sheet with several elevations, is there a way to differentiate
between distant and close up walls and the like. Also, can you do the same
for a 3D model that shows ie. a parapet on a back wall that I want grayed
out? Thanx!
