Display vs printing of symbol
1 REPLY 1
343 Views, 1 Reply
I have just started using Revit, so everthing is still set up out of the box. I create a floor plan, set to "show complete" and add the Revit included floor drain symbol, set to "existing". This displays and prints as expected.
When I create the demo plan, set to "demo + previous" the floor drains show, but do not print. They will print using raster instead of vector processing, but other line work such as regions look bad.
I have seen other posts similiar to this problem, but not a solution yet.
Chad
1 REPLY 1
Alfredo_Medina
In the Print Setup dialog box, select "Vector processing" and, from the options at the bottom of the screen, activate "Replace half tone with thin lines".
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
