Hello.
Can someone please chime-in and explain the logic behind the differences
between RVT Categories and how they display in Plan View?
Example:
I made a custom component (Family) that was set as the 'Generic Model'
Category.
When placed, its elevation was set above the Cut Plane but below the Top of
the Primary View Range for the Plan View.
The Object displayed in its entirety.
I then decided that this component was really better categorized as
'Specialty Equipment'. So, I re-assigned it in the Family Editor, and
re-loaded it into my Project. As I did this, the object disappeared from
Plan View. I then switched to a 3D View to verify it was still present in
the model - and it was.
So why does Generic Model Display, and not Specialty Equipment, I ask?
I've discovered that if I lower the Elevation of the Specialty Equipment to
exist at or below the Cut Plane, but above the Bottom of the Primary View
Range; it will display in Plan View.
I've also tested and discovered that adding Symbolic Lines to the Plan View
of the Specialty Equipment in the Family Editor and re-loading into the
Project will not overcome this issue of elevation - if the object is above
the Cut Plane the Symbolic lines will not display either.
I note that Specialty Equipment does not have a "Cut" setting for
Lineweights in Object Styles, and Generic Model does.
Is this the indicator for this display behavior that I'm experiencing?
And if so, why is 'Specialty Equipment' regulated to this type of Category?
Why not have a 'Cut' setting for it?
Quite a fair bit of an Architectural model gets lumped into this Category:
lockers, toilet accessories, kitchen equipment, medical equipment, etc.
Seems very short-sighted, to me, to limit the Category in this way.
