Display Error (An error has occured while drawing the contents...
1 REPLY 1
1235 Views, 1 Reply
sometimes when I select some object (component), the "Display Error" appears and the view is closed after i click OK.
I use Revit 2013 (Student Version) / Windows 7 / HP Pavilion dv 7 / NVIDIA GeForce GT 230M (driver 310.90)
I turned graphic acceleration already off.
Maybe the problem could be in the graphic driver -  I updated it some time ago. Before some time Revit 2013 worked for me, but then i uninstalled it.
Thanks for any help.
1 REPLY 1
I have disabled also "Semi-transparent" option in the graphic options menu and now it works, but only in all 2D views.
While opening any 3D view the "Display Error" window appears. Also in the basic sample project...
Please, any help?
