Disappearing Windows
1 REPLY 1
177 Views, 1 Reply
When I tried to make and Interior Elevation view of my kitchen in Revit Architecture 2013, the veiw that came up did not have the window i had placed in my floor plan.  It is not hidden in the view as I thought it might have been, it jsut simply is not appearing within the view. Does anyone have a possible solution I could try to use.  Any help or comment is greatly appreciated.
1 REPLY 1
LisaDrago
Can you post an image? Images can help a lot.
Can you take a snapshot of the plan view of the elevation marker with the boundary highlight and the elevation view.
Is the depth of the elevation marker going beyond the wall? Is there anything in front of the windows to block the view? (I am figuring there isn't but never hurts to check)
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
