Disabled the Boundary Line option in Revit
6 REPLIES 6
BIMAbhi
720 Views, 6 Replies
Having Revit 2012 or 2013 we have installed another version of Revit (2014) in my system. We have been facing a problem when modifying any object (i.e. ceiling, roof etc.).
Problem:
Disabled the Boundary Line option (Tick and cross) for floor creation
We have attached a pdf file for your reference.
Thanks in advance!
Thanks & Regards
BIMAbhi
6 REPLIES 6
loboarch
in reply to: BIMAbhi
You need to install updates to Revit 2012 and 2013 to reslove the issue.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
BIMAbhi
Can you please provide us the updates.
Thanks & Regards
BIMAbhi
loboarch
All of the updates can be found here.
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=21208796
Jeff Hanson
Revit Help |
BIMAbhi
Can you please mentioned the name of the update which resolve our mentioned issue for Revit Architecture 2012. See the attached snap.
For Revit 2013 we have downloaded the below mentioned update tool.
1. Revit Architecture 2013 Update Release 3
2. Revit Architecture 2013 Update Release 2
3. Revit Architecture 2013 Update Release 1
Please confirm.
Thanks & Regards
BIMAbhi
loboarch
For 2012 apply the Hotfix for Ribbon behavior caused by .NET 4.5. For 2013 Update release 3 should solve the issue.
Jeff Hanson
Revit Help |
BIMAbhi
Thanks for your all support.
Thanks & Regards
BIMAbhi
