John,
You can control the units per project AND per dimension type. To change the
project units go to the Settings menu and select Project Units.... The units
for a particular dimension type can be changed simply by editing the Units
Format.
I don't believe u can round temporary dimensions up or down. "Is what It
Is". If someone draws a wall 50' 6-255/256"........ that's what will show up
as a Temp. dimension.
Paul Monsef
TSA | architects, pllc
Production/CAD Manager
425.401.6828 x105
"John Herridge, AIA" wrote in message
news:4006f6a6_2@statler...
> If rounding dims to the nearest 1/8 inch, what settings have to be changed
> to make permanent and temp dims be the same value?
> John Herridge, AIA
> AEC CADCON, Inc.
> www.aeccadcon.com
