It is first time i encoutered quiet an anusual problem with dimentions. Having dimentions rounding set to one decimal place, and hide trailing zero's some dimentions show value like: 7340,999999999999
When I measure the same elements, but dividing it into rooms or grids, all dimentions seem ok, and work without rounding. I can't imagine writing dimentions as text with some "invisible dots" and it is rather uncommon to print final drawings with this kind of dimentioning.
Does anyone found a solution for that problem, was it ever encountered?
Best Regards
Solved by LukaszMaleszewski. Go to Solution.
Open the type properties of the dimension, open Units Format. Maybe "Use project settings" is off?
Nope,
I tried both ways (settings in dimention family and settings in project units).
Anyway the problem got fixed, by update 2, which i luckily installed because of some other error 😄
Best Regards
