I open my Revit 1file and w/o explanasion the dimensions have changed. I made sure everything was locked but still happened. Finally got everything locked and started roof plan...looked at 1st and 2nd floor and dimensions changed once I put roof on...confused?
Can you post some images of what is going on?
the only way of dimensions changing is if object are being moved.
LD
