The ref planes wont print if you check the box in the print dialog box, so
you could just leave them on. (unless they bug you bring there?)
wrote in message news:5043982@discussion.autodesk.com...
Hello -
I have a bay window, walls on 45 degree angles, on my project that is very
difficult to dimension. No matter what dimension method I choose I cannot
pick the intersections of the core faces for dimensioning. So, I set some
reference planes along the face of the core and I was able to dimension the
walls. However, if I turn off the visibility of the reference planes in that
view my dimension leave with them. I found a work around to hide the
"reference plane annotation" one by one in the view so they no longer are
seen.
Am I missing something? Is there a proper or better way to do this type of
dimensioning? Any and all comments are welcome.
Cheers - Tay
