However this does have the drawback of not being able to use the dimension
to parametrically move the column and the grid line. If you lock the grid to
the column and then try to change the column dimension, you will get an
error. Since grids are shared in worksets, this may cause other issues with
keeping objects coordinated.
"Frame" wrote in message news:4002b8bd$1_2@statler...
> For the dimension to recognize a centerline, dimension to the column
center
> rather than the grid line.
> This should allow you to get dots on column lines and ticks on wall edges.
> Just remember that with this dimension style, the dot will show up
anywhere
> the dimension references the center of any object, such as windows, doors,
