Hi all,
Surprised I've not come across this before, but there you go.
Circular opening in a slab. For setting out purposes I need to have an aligned dimension from grid line to the center of the opening. I have 'centre point' turned on in sketch mode but as soon as I leave sketch mode I can no longer select this making it impossible to assign the dimension.
Does anyone know how this can be done? Surely it's possible?
(tried this in both RVT 2013 and 2015 with the same results).
Cheers
K.
Solved by constantin.stroescu. Go to Solution.
In Project mode :
Your Name
Thanks. I'll give that a go.
But why on earth can a reference plane detect the center point and a dimensions can't? Bit odd...
