Revit Architecture
Revit Architecture
Valued Contributor
1 Kudo
Post 1 of 3
Dimension text color change
1821 Views, 2 Replies
03-24-2011 11:26 PM
This is wahid using Autodesk Revit Architecure 2011, My question is when i am using Anotation i want to change Differant color to Dimension line and Text. It is not happening.
If anybody knows please reply me.....,
Regards
wahid
+919880643891
s1623jn26@yahoo.fr
Active Contributor
0 Kudos
Post 2 of 3
Re: Dimension text color change
03-25-2011 05:47 PM in reply to: s1623jn26
I am guessing that you want the various components to be different colors like you can do in AutoCAD.  If that is correct and you are wanting the dimension text to be a different color than the dimension linework, that is not possible in Revit 2011.
If you are wanting all of the different components of a dimension to be the same color, but other than black, you can change that in the dimension type properties.  Select the desired dimension type, pick the Edit Type button in the Properties palette, then go to the Color option under Graphics to choose the desired color.
Douglas Bowers, AIA, LEED AP
www.dougbowersconsulting.com
blog: http://aectechtalk.wordpress.com
(Previously posting as Doug Bowers through Newsreader for several years)
Valued Contributor
1 Kudo
Post 3 of 3
03-25-2011 08:39 PM in reply to: s1623jn26
Thanking you sir.......,
Post to the Community
New Post
