Alrighty, I was hoping some form of drag and type the distance to offset the
dimension string from.
"sdbrown" wrote in message
news:21048241.1096392635083.JavaMail.jive@jiveforum2.autodesk.com...
> just place a detail line where you want it, then drag the dim to that
location. Revit lets you set the offest between dimensions strings in the
property of the dimension, but not from objects.
