How can I make a dimension like this for the circle? (See attached image)
Can I just do an aligned dimension of a circle WITHOUT drawing the reference lines?
In AutoCAD, you choose the quadrant or tangent point of the circle for dimension like this. How can you do this in Revit?
Also, can you make the 2d lines to act like "DEFPOINT" in AutoCAD? Meaning you can see the lines but won't be printable on the plots.
Thanks in advance.
Solved by constantin.stroescu. Go to Solution.
https://screencast.autodesk.com/main/details/6efcbdd0-c457-461b-a0cd-b6c82074e57e
Your Name
When I said "circle", I meant the circular column.
This is what I want to achieve, see attached. I want to align all column dimension on one side of the grid line.
But it couldn't recognize the intersection point between the grid line and the column.
I had to draw 2 little detail lines just for the referencing of aligned dimension.
Try using reference planes. they do not plot and you can dimension to them.
if you speak about a Family , a Structural Column Family can be made so to allow Aligned Dimensions:
I've attached such a Family....
Your Name
Thanks a lot. It's very helpful.
I still can't imagine why can't Revit make it easy instead of creating a family just for this simple dimensioning.
You do not need to add Reference Lines, unless you want to do so. You can select the existing Reference Planes that are tangent to the quarter points and change the Is Reference property from Not a Reference to Weak Reference or Strong Reference. If you change them to Weak Reference, then the two "Center" Reference Planes will have first priority when placing dimensions or choosing alignment planes. If you make the Strong References, they will have equal priority with the "Center" Reference Planes.
Thanks for the clarification. I didn't know you can switch to strong or weak reference. I'll look into it. Thanks.
you are right David....
Using Strong/Weak instead of Not a Reference is much simple and elegant than using Reference Lines....Anyway the changes must be made in the Family file
Constantin
Your Name
