Dimensiion strings
1 REPLY 1
idraw38
190 Views, 1 Reply
Dimensiion strings
Revit 2011. How is it possible that a string of dimensions can be 1/2" off from the total dimension?
1 REPLY 1
scott_d_davis
in reply to: idraw38
Your dimensions are set to round off.  This could be in the properties of the dimension itself, or dimensions can be set to display project Units.  Check with the properties of a dimension first.
Scott D Davis
Sr AEC Technical Specialist
