How can I use one text box with different text sizes?
Solved by CoreyDaun. Go to Solution.
You can't mix text sizes in one element in Revit. You would have to use seperate text elements to get different sized text.
You cannot create a single text box with different text sizes or even different colors. Even if text is pasted from another program, it is forced to the font size that the Text Type dictates.
