Details components and Callouts
1 REPLY 1
Paul_Blanchard_Ghafari
359 Views, 1 Reply
Good Morning,
Is there a method to have detail elements in the parent view (section) pass into the child view (Detail View)?
Procedure I used
1. Created a section
2. Added Detail components for a wall section
3. Created a callout
Tags (2)
1 REPLY 1
Detail components are considered annotation - therefore they are view specific and only show up in the view you place them in. It would be advisable in this instance to put your detail components in the callout view and not the section view.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
