I created a wall detail in a scale of 3/4"=1' and when I change the scale to 3"=1' the hatching becomes smaller. I want the hatching to get larger without having to redraw it. Is this possible?
Solved by Alfredo_Medina. Go to Solution.
If you refer to a filled region, the hatch pattern becomes smaller because you are using a drafting pattern, which changes with the scale of the view. A model kind of pattern would keep the same size, regardless of the scale.
However, if you are referring to the cut pattern of a wall, in that case the only kind of pattern allowed is drafting. You cannot apply a model pattern for the wall, but you can cover it with a filled region in a section or detail view, if necessary.
