Detail Item stretch diagonal
2 REPLIES 2
mocito.agostinho
904 Views, 2 Replies
Can anyone tell me if it is possible to create a Detail item with Instance Parameters contraints so that I can adjust to get both solutions? (see image)Capture.PNG
I guess the solution could go along some diagonal stretch of the diagonal lines?
thanks in advance.
J
Revit 2014
AutoCAD 2014
Tags (1)
2 REPLIES 2
To control diagonals, first, take control of horizontal and vertical reference planes by parameters. Then, simply draw diagonals from intersection to intersection.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
tricky autodesk.
but it works, with a bit of work. thanks. 🙂
Revit 2014
AutoCAD 2014
