Can anyone tell me if it is possible to create a Detail item with Instance Parameters contraints so that I can adjust to get both solutions? (see image)
I guess the solution could go along some diagonal stretch of the diagonal lines?
thanks in advance.
J
Solved by Alfredo_Medina. Go to Solution.
To control diagonals, first, take control of horizontal and vertical reference planes by parameters. Then, simply draw diagonals from intersection to intersection.
tricky autodesk.
but it works, with a bit of work. thanks. 🙂
