Detail component fills
6 REPLIES 6
blastula99
222 Views, 6 Replies
I posted a similar question last week.
Can someone please tell me if there is a way to have detail components (plywood, rigid insul, etc.) have their fill patterns align properly?
I find it inconceivable that the patterns only work one way. This pretty much renders them useless. Am I missing something or this the case.
Any help is much appreciated
6 REPLIES 6
in reply to: blastula99
yes you can. The Fill pattern has an "Orient in Host Layers:" Go to the
Fill Patterns properties from the Settings pulldown.
wrote in message news:5451774@discussion.autodesk.com...
This would be true for a model object - but does not apply to filled
regions....
"Bobby W Parker" wrote in message
news:5451891@discussion.autodesk.com...
blastula99
Thanks, but I found the answer I needed on another forum.
Basically the new detail components in R9.1 don't align in any other way- previous releases did. I found a modified component someone made for working around this.
Could you please share as we are having the same problem.
wrote in message news:5452152@discussion.autodesk.com...
around this.
blastula99
I don't know the protocol around here but I found alot of discussions about this issues at AUGI. Here is one link to a post:
http://forums.augi.com/showthread.php?t=43641&highlight=fill+pattern+detail+component
Good luck!
Augi is a Autodesk sponsored website, so I can't imagine anyone would having
a problem with it. Thanks!
wrote in message news:5452202@discussion.autodesk.com...
Good luck!
