Revit Architecture
Revit Architecture
*Brian Winterscheidt
Message 1 of 11 (2,664 Views)
Detail Component Fill Patterns - Align to Element
2664 Views, 10 Replies
08-28-2007 11:49 AM
How do you make it work?
I've utilized the Plywood-Section detail component out of the Imperial
Library, and it runs left-to-right, no matter the orientation of the
element I drew. Messing with the Fill Pattern settings, it looks
identical if I set the Plywood-Align pattern to "Align to Element", or
"Orient to View". Nothing changes.
Am I missing something, or does it simply not work?
Brian Winterscheidt
LWPB Architecture
Oklahoma City, Oklahoma
Message 2 of 11 (2,664 Views)
Re: Detail Component Fill Patterns - Align to Element
08-28-2007 11:54 AM in reply to: *Brian Winterscheidt
> element I drew.
Here's a screenshot.
Brian Winterscheidt
LWPB Architecture
*Jeff Hanson \(Autodesk\)
Message 3 of 11 (2,664 Views)
08-28-2007 12:19 PM in reply to: *Brian Winterscheidt
Align to element settings does not work with detail components. :-(
Jeff Hanson
Autodesk - AEC Technical Publications
Manchester, NH
_______________________________________
"Brian Winterscheidt" wrote in message
news:5703490@discussion.autodesk.com...
Brian Winterscheidt
LWPB Architecture
Active Member
pgrimmi
Message 4 of 11 (2,664 Views)
08-30-2007 07:14 AM in reply to: *Brian Winterscheidt
this is a very common pattern for plywood and if we cannot have the hatch patterns orient the way we need them to it does us no good to spend the time creating details in revit.
i have exactly the same problem (see attached file).
is there a way around this fill pattern orientation problem?
Regards
pgrimmi
*nicholas
Message 5 of 11 (2,664 Views)
08-30-2007 09:35 AM in reply to: *Brian Winterscheidt
Is this functionality in the offing for the next release?
We currently do a fill pattern and rotate it per the rotated ply and live
with this....
(dont shoot me for this ridiculous workaround...)
n
"Jeff Hanson (Autodesk)" wrote in message
news:5703539@discussion.autodesk.com...
Jeff Hanson
Manchester, NH
Brian Winterscheidt
LWPB Architecture
Active Member
pgrimmi
Message 6 of 11 (2,664 Views)
08-30-2007 10:47 AM in reply to: *Brian Winterscheidt
i've tried this too and i could never get it to work...how did you do this?
Message 7 of 11 (2,664 Views)
08-30-2007 10:52 AM in reply to: *Brian Winterscheidt
This issue has been logged with the development team for consideration in a
future release of Revit.
Jeff Hanson
Manchester, NH
"nicholas" wrote in message
news:5706105@discussion.autodesk.com...
with this....
*nicholas
Message 8 of 11 (2,664 Views)
09-10-2007 09:53 AM in reply to: *Brian Winterscheidt
The fill pattern type has to be "Model" to achieve this.
hth
wrote in message news:5706271@discussion.autodesk.com...
New Member
alanier
Message 9 of 11 (2,664 Views)
12-03-2007 07:32 AM in reply to: *Brian Winterscheidt
One workaround we just made was to edit the plywood Detail Component family and add a filled region with a vertical orientation (on top of the horizontal one). Reconstrain the new region with the same parameter as the original (Thickness). Now add two visibility yes/no parameters, one for vertical and one for horizontal. This way when you create a piece of plywood you can select in the object properties whether it should display as vertical or horizontal.
I guess if you want more angles they could be created, too.
Distinguished Contributor
SharlaL
Message 10 of 11 (2,475 Views)
03-07-2011 03:58 PM in reply to: *Brian Winterscheidt
Has this been resolved yet? All these work around's on our first Revit project are driving me crazy!
Post to the Community
New Post
Need installation help?
