You don't need the original .PAT file as you can load ithat family to a new project then export from the HatchKit Add-In for Revit.
;;*** Fill exported by the HatchKit Add-In for Revit
;;*** Copyright (c) 2013 - 2017 Cadro Pty Ltd
;;*** www.hatchkit.com.au
;%VERSION=3.0
;%UNITS=INCH
*Plywood_TN_Model,HatchKit Add-In for Revit
;%TYPE=MODEL
45,0.29419,0,3.53553391,-0.70710678,2.82842712,-5.65685425
45,0.42678,0,3.53553391,-0.70710678,2.82842712,-5.65685425
45,0.55936,0,3.53553391,-0.70710678,2.82842712,-5.65685425
0,0,0.5,-3,2
0,0,0.75,-3,2
0,0,1,-3,2
0,0,1.25,-3,2
0,0,1.5,-3,2
0,0,1.75,-3,2
0,0,0.25,-3,2
0,0,2,-3,2
what about plywood sheathing in a roof detail? do I have to match a separate pattern for every roof slope.??
This does not work as a drafting pattern with is required with detail components. Does not help for Detailing.
It does if you create the plywood as a detail.component family. It does not work if you create filled regions directly in project.
Thats perfect! Now how can i use Model fill patterns in a drafting view?
I think you are confused by the terminology.
You can use model fill patterns in any views: model views, drafting views, legend views. The difference between a model pattern and a drafting pattern is that a model pattern represents true dimensions (think brick, tile, cmu patterns on an an elevation), where as a drafting pattern represents the printout dimensions (think cut pattern for brick, cmu walls on a plan).
ToanDN is correct. The best solution is to use a Detail Family. Use a Line Based template for plywood, and you have to use a model fill pattern for this to work. It is odd that drafting fill patterns say they will orient - but will not in fact do so.
Run, don't walk, and grab the pyRevit plugin. It is free. Place a filled region using the plywood type. It is a drafting-type pattern and doesn't rotate or align. Select this pattern and then use pyRevit's "Make Pattern" tool. This will create a model-type fill with the same pattern that you can now tab-select the hatch lines and rotate or move them. It also makes it super-easy to create custom fills, as well as import .PAT files via single or batch imports. Previously, I had a custom line-based detail component, but corners didn't work great. This does. Enjoy!
