Desing Option and halftone
2 REPLIES 2
bines
3551 Views, 2 Replies
I'm working on Design options. I've created three separate views that show the different design options. Is there a way where I can have the items that stay the same in all three views to show as half tone?
Kind of like how Revit puts everything in halftone when you're editing your design option.
I just want the changes to pop out more.
Please advise. Thanks,
Bernard
2 REPLIES 2
Alfredo_Medina
in reply to: bines
One way could be this: from a 3d view, make sure that "exclude options" is active at the status bar. Switch the design option to "Main model". Make a window selection that encloses everything. Then do > Override graphics in view... > By element... > Halftone.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
brasch9XHLD
in reply to: bines
Be prepared to work around. I've found the most effective way to complete this is to make a work-set that hosts your design options (I like to label mine Options, Design). Then you need to go into visibility graphics and create a filter for your work-set that hosts the main model (typically this is Workset1). This way when you are in a design option view (don't forget to enable the "Options, Design work-set), you can simply go into visibility graphics, then filter tab, halftone your main model work-set (typically Workset1).
