I am not getting the behavior you describe when I try it. All walls are showing detail. I'm not sure what's causing the problem you
are seeing, but I doubt it has anything to do with design options. Perhaps the walls are entirely below the cut plane of the view,
or the wall type has no compound structure.
wrote in message news:5161138@discussion.autodesk.com...
How do I get the detail of the walls to show when I am displaying option 1 for example - okay here is what I am doing. I have all
the walls of the main builinding done I then created an option 1 for some offices and stuff. I then created a call out so I could
enlarge it on a seperate sheet but when I turn my detailing from course to medium only the walls that were done on the option 1 show
detail and I need for 'all' walls to show detail.
