Dependent Views - Can't create one based on a Drafting View?!
Is this for real?
I use dependent views to split things that are too large on two separate sheets. Some flow charts and other data has to be split... but the option is greyed out.
Yep, it's for real. Currently (as of Revit 2014), one cannot create Dependent Views from a Drafting View, nor can one even crop a Drafting View. I'm afraid that the best you can do may be to Duplicate with Detailing and manually modify the linework as necessary.
On a similar note, on some previous projects, we have imported our 'master details' in the form of a DWG file. The method I used to break up the various details in the single CAD import was to:
1. Create a new Floor Plan View.
2. Turn off all Model and Annotation Categories.
3. Import/Link the DWG file with the option "This View Only".
4. Create Dependent Views and Crop Regions as needed.
Although this is geared towards CAD Imports, perhaps this technique could be slightly altered for use with native-Revit details & diagrams.
Just out of curiousity, what exactly are you putting in a drafting view that needs to be split up over multiple sub-details? Could you post an image of a sample desired result?
I'm thinking you could create an annotation phase (set either before "Existing" or after "New Construction") and detail your elements in a plan view there, then you could use dependent views. Just a thought.
Out of interest how do you assign a 'Drafting View' to a phase?
@Anonymous wrote:
We regard phasing in Revit as broken, it just doesn't fit our scenario. We use parameters to manually assign each sheet to a phase and other means to organize content.
Revit seems to want to manage everything, but Autodesk does not realize that some offices will never open their IP to them so they can build the tools so everyone can build something similar. We only use Revit because of the parametric engine and the seamless worksharing capabilities. I can't begin to list all the "features" it's missing to do all our work. We have some luck with some of the tools but others are just plain impossible to use in a big team without major problems down the road.
It's difficult to be of more help without knowing what it is you do. Is this for an architectural project, or some other field? It sounds like you're using Revit for a non-architectural type of project, and if so, you're probably going to run into problems, because it's geared specifically towards how architects, structural engineers, and MEP engineers work.
Also, what does "open their IP" mean? Are you talking about the API and writing your own add-ins to run on top of Revit?
basilmir wrote:
"We have some flow charts and a lot of diagrams... They are large and we usually split them in multiple sheets. But the person working on them has to see the big picture all the time."
So, using the Plan View with Dependent Views method as I explained previously should work, then. The author will be able to see and work on the diagram in its entirety in the 'Master' Plan View, while the Dependent Views are cropped and placed on Sheets.
