Dependent Dimensions, Independent Graphics
2 REPLIES 2
516 Views, 2 Replies
We have a need for multiple sheets to use the same dimensioning, however independent visibilty graphics options.  Dependent views get us halfway there as far as the dimensions go, but fall short when we need to apply a filter to just one of the views.  Any suggestions or work arounds would be appreciated.
2 REPLIES 2
LisaDrago
Unfortunately there isn't a real workaround - this is only because dimensioning is considered annotation - therefore view specific. The view you place it in is the only view you will see it.
Not the answer you were looking for - I know.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
CoreyDaun
Is there a particular reason that the Dimension Elements cannot be copy/pasted to each View? (You can Copy the desired Dimensions to clipboard and then Paste Aligned to Current View to quickly duplicate the dimension layout.)
One work-around would be to create a dedicated View for those particular elements and their dimensions and overlay that View on top of the primary Views on the Sheets. You can create a Dependent View of this dedicated View in order to overlay it on multiple Sheets.
Welcome to the Autodesk forums, bhinojosa!
Feel free to post any questions you may have! There are many experienced users here who generously contribute their time and effort to supporting
their peers. This is an open, peer-supported forum, so feel free to contribute any useful information or experiences to any of the topics you see here.
We hope you'll stick around a while and help strengthen the value of this community!
Be sure to review the Ground Rules, visit the FAQ Forum, and use the Search feature prior to posting a question, as it's likely been asked before.
