Once worksharing is enabled in a Revit project it can not be un-done. The
detach from central option simply allows the file to be opened as if it was
a file that just enabled worksets. It still will save as a central file
when saved, it just does not have any connections to the original central
file.
Jeff Hanson
Autodesk Product Support
Building Solutions Division
Manchester, NH
_____________________________
wrote in message news:4955847@discussion.autodesk.com...
Hi all.
Is it possible to delete all worksets in a file so it can turn into a
"normal" file with no worksheets or save to central?!
I just want a local file no needing requests from other users, they finished
their job and its only me who is going on with it from now on.
I saw there is a new check box in 8.1 when opening to detach from central,
but when save, it saves to a new central file.
Thanks for any help.
Miguel Miranda
