Just tested it, works fine here, X icon and the Delete key.
"Alfredo Medina" wrote in message
news:5522359@discussion.autodesk.com...
Even having the outside boundary selected, the delete key won't erase the
ceiling, and the 'X' icon for erasing objects keeps disabled.
Only right click>Delete works. Seems like a bug.
"C Ryan" wrote in message
news:5522357@discussion.autodesk.com...
I believe you have to get the outside boundary. If you are selecting a grid
line I don't think it'll work.
news:5522347@discussion.autodesk.com...
Daniel
Thank you for your help. However, I had already tried that, even using Tab,
but the ceiling just stays there after I hit the Delete button, and the
Delete icon keeps disabled. Any other ideas?
Never mind! I have just found the way. The only way to delete the ceiling is
by using rick click>Delete, after the whole ceiling is selected with Tab.
All the other options don't work.
Alf
wrote in message news:5522274@discussion.autodesk.com...
Go to a ceiling view plan. Select your ceiling (might have to TAB) then hit
delete
