Default templates are not there. How to find them?
2 REPLIES 2
642 Views, 2 Replies
I have just installed Revit 2015 on my new computer and have run in to a problem. When I go to create a new project, none of the default templates are loaded. I get an error that reads "The path you have specified for the default family template files is invalid. The change the default path, from the application menu select options, and then the file locations tab." I have located the options tab on the application menu and the file locations tab and cannot figure out where and how to fix this problem. Any insight on this topic is much appreciated!
2 REPLIES 2
BIMgirl
The templates should be located here: C:\ProgramData\Autodesk\RVT 2015
If they are not there, then probably you didn't install the content during the installation process - either you deselected this option, or something went wrong, in this case just run the installer again.
Cheers, Lejla
Lejla Secerbegovic - Architect and Revit Expert
http://bim-me-up.com
in reply to: BIMgirl
Thank you for your help. I did reinstall and that worked.
